NAVIGATION / Midwest Audio Club / Forum / Gallery / Wiki / Design
Design
A knowledge base of DIY audio design, with links to other resources as well.
Common Tag Glossary
This is a glossary of common tags used on the forum, by their general category. Most of these are focused primarily on aiding the search of the DIY forum category.
Box
sealed-box:
ported-box:
bandpass-box:
passive-radiator-box:
dipole:
bipole:
h-frame:
u-frame:
bookshelf:
floorstanding:
aperiodic:
Driver Compliment
fullrange:
two-way:
three-way:
four-way:
five-way:
subwoofer:
tweeter:
midrange:
midbass:
woofer:
super-tweeter:
MTM:
TM:
TMM:
TMW:
ribbon-planar:
ring-radiator:
Crossover
passive-xover:
active-xover:
DSP:
notch:
baffle-step:
1st-order:
2nd-order:
3rd-order:
4th-order:
5th-order:
6th-order:
8th-order:
FIR:
IIR:
parametric-eq:
graphic-eq:
phase:
delay:
General / Others
